/interface ppp-client info ppp-out1 user-command="AT^HCSQ\?"
Hi!
I would like to collect the quality of LTE signals (as RSSI, RSRP, SINR and RSSQ). I use for it the Mikrotik RB951Ui-2HnD and the modem Huawei E3372.
I can see this parameters if I use the command AT^HCSQ?
/interface ppp-client info ppp-out1 user-command=“AT^HCSQ?”
modem-status: ready
pin-status: no password required
functionality: full
manufacturer: ^HCSQ:“LTE”,56,47,101,18
model: E3372
revision: 21.285.01.02.143
serial-number: 864346021423076
current-operator: MTS RUS (cellid 117d03)
access-technology: Evolved 3G (LTE)
signal-strengh: -65 dBm
frame-error-rate: n/a
– [Q quit|D dump|C-z pause]
How do write a script who collect the red line?
I need help.
UP!
I have no way to check this, but you can try
:global manuf;
/interface ppp-client info ppp-out1 do={
:set manuf $“manufacturer”;
Thanks, dbdom.
It works!
But, i don’t know how run script for only one time.
:global manuf;
/interface ppp-client info ppp-out1 user-command=“AT^HCSQ?” once do={
:delay 10
This is don’t work.
How to split this value ^HCSQ:“LTE”,56,47,101,18 ?
I would like to get 5 value:
Signal = LTE (maybe WDMA)
RSSI = 56 (the first)
RSSP = 47 (the second)
SINR = 101 (the next)
RSRQ = 18 (only for LTE).
ex.:
^HCSQ:“WDMA”,45,147,60
^HCSQ:“LTE”,58,39,99,32
Thanks!
I used the following command to write AT-command in Terminal
/system serial-terminal usb1 channel=2
WRITE UR AT COMMAND ( e.g. AT^sysconfig?)
actually, I was using MikroTik basebox 5.
