I am trying to set up rate limiting on an Ethernet port that is on a bridge. I want to use a device to aggrigate everyones traffic while restricting a single port to 30Mbps. I have the device set up with a single bridge that all ports are assiciated to. I then set a simple queue on one of the Ethernet ports but it doesn’t work. The simple queue works if it is on a port that isn’t part of the bridge but not when its part of the bridge.
Due to my IP limitations I have to have the device bridging all of the ports. Is there a way to limit a spacific Ethernet port that is part of the bridge?
