Interface route w/o IP address: how?..
[admin@MikroTik] > /interface vlan add name=vlan1 interface=ether1 vlan-id=123 disabled=no
[admin@MikroTik] > /ip route add gateway=vlan1
[admin@MikroTik] > /ip route print detail
 1   S  dst-address=0.0.0.0/0 gateway=vlan2 gateway-status=vlan2 unreachable
        distance=1 scope=30 target-scope=10
[admin@MikroTik] >
is it possible to make it reachable w/o adding ake IP address to the intrfacve? even setting ‘pref-src’ to any router address do not solve the task :frowning:
Sorry my reply is not correctly precise.
  1. Interface route works for multi-access interfaces, when it is possible to resolve DST-address by ARP. When DST-address is directly reachable from the same router or there is any other router in the network with proxy-arp.
  2. Why can’t you just assign address to the vlan interface? In recent RouterOS
    versions it is even possible to have the same IP address on multiple interfaces.
actually, I need it for IP Tunnel interfaces…
so, it works only for /32 routes?.. or how will it resolve subnets?..
well, that’s what I do, but I’d like not to add many identical addresses - it’s not very beautiful =)
and if I need it for asymmetrical routing (one router for upload, another one for download) - why should I add address for download interface?..
I think, at least for tunnel interfaces, there should be no need to add an address…
In the case of proxy-arp routing, I just add a 10.0.0.1/32 to the interface. No big deal.
