RB750 v4.2:
Interface → Ethernet → etherX → Bandwidth Rx/Tx
If you set this to 16, the error is: “min 32k supported”
So then, if you set this to 32k, the error is: “decimal number expected”
Ok, and now if you set this to 64k, the error is: “rx/tx limiting not supported on this interface”
Why is this option here then? Do ANY routerboards support limiting bandwidth directly on the interface?
