HI
I want to take Interface tx byte and rx byte backup and email every 6 hour. can any one help me?
Tuhin
HI
Tuhin
Write a script that is scheduled to run every 6 hours. In that script use this command to get your current rx and tx values:
:local tx [/interface ethernet get <interface> driver-tx-byte]
:local rx [/interface ethernet get <interface> driver-rx-byte]
Thanks for the reply
But how to see the value and email it?
Tuhin
Change username, password and ether1-LAN to your values
/tool e-mail
set address=0.0.0.0 from=username@gmail.com password=pass port=25 starttls=no user=username
/system script
add name=script1 policy=ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api source="#get tx - rx\r\
\n:local tx [/interface ethernet get ether1-LAN driver-tx-byte]\r\
\n:local rx [/interface ethernet get ether1-LAN driver-rx-byte]\r\
\n\r\
\n#get name date and time\r\
\n:local name [/system identity get name];\r\
\n:local date [/system clock get date];\r\
\n:local time [/system clock get time];\r\
\n\r\
\n#make subject message\r\
\n:local sub (\$name . \" - \" . \$time . \" - \" . \$date);\r\
\n#make body message\r\
\n:local bod (\"Ether1-LAN - TX: \" . \$tx . \" - RX:\" . \$rx);\r\
\n#send e-mail\r\
\n/tool e-mail send to=\"username@gmail.com\" subject=\$sub body=\$bod server=[:resolve smtp.gmail.com] tls=yes;\r\
\n\r\
\n"
/system scheduler
add disabled=no interval=6h name=script1 on-event=script1 policy=ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api start-date=dec/11/2013 \
start-time=12:00:00
You can also use SNMP requests from some server of yours and store the result the way you want (file, dataase, mail, whatever). SNMP command-line clients are widely available.
