Interface Tx / Rx Monitor Setup
The setup I am trying to accomplish is to be able to monitor the Tx and Rx rate of a certain port on a switch, I select my device from the device list and go to SNMP > Interface tab and it will show the list of ports and current usage that way, but I would like to put this info into a chart that I can lookup usuage for the past hour, week, month etc. I have tried to setup probes with several different OIDs but am having no luck.
Any help is much appreciated!!
Just create a link to a static from your switch or router then you can pick that in a chart…
Well that was easier than I was making it out to be!
Thank you very much
Yeah the dude is still so awesome.
