Interface Upload Showing Traffic
Please check the snapshot below.
I am using RB2011Uias, Ether1 is Wan and Ether5 is Lan, from 2 days I am observing that this difference.
Usually the TX of WAN and RX on LAN were symmetric and RX on WAN and TX on LAN were symmetric, but now its showing a lot of difference.
Is my connection compromised
I use UBNT hardware for my Wireless distribution and I don’t see any unauthorised devices connected
Please suggest.
Again and again and again. It’s almost each day the same. Search the forum first. Then drop incoming traffic to port 53 both tcp and udp on wan interface.
Hello..
The way to fix that issue, is to go to IP > DNS > unchecked remove " allow dns remote request" This will fix the issue.
I guarantee you.
Cheers…
