Interface: USB
Hello. Can mikrotik router OS support DHCP via USB? I have Modem that use USB, usually I use it on PC, but now I want to share with other, so I must plug the USB to my PC Router… Thanks…
It will not support your USB modem.
most modems ( cable ? ) have both ethernet and USB … and you can either use one or the other, but not both at the same time. Is this a cable modem ?
