[/interface wireless find] Question
Good Day,
I am in the process of setting up firewalls on all of my sector antennas to prevent clients to communicate with common services over the network.
I know our CPE password got leaked some how and that the password can be extracted from a backup file.
I want to prevent @%*#ers from running a vb script from inside the network to reset other radio’s on the network.
This is what I use at the moment and it seems to be working fine.
add chain=forward action=drop protocol=tcp dst-address=10.0.0.0/8 in-interface=[/interface wireless find] dst-port=21 comment="Drop FTP From Clients to Clients"
add chain=forward action=drop protocol=tcp dst-address=10.0.0.0/8 in-interface=[/interface wireless find] dst-port=22 comment="Drop SSH From Clients to Clients"
add chain=forward action=drop protocol=tcp dst-address=10.0.0.0/8 in-interface=[/interface wireless find] dst-port=23 comment="Drop Telnet From Clients to Clients"
add chain=forward action=drop protocol=tcp dst-address=10.0.0.0/8 in-interface=[/interface wireless find] dst-port=80 comment="Drop HTTP From Clients to Clients"
add chain=forward action=drop protocol=tcp dst-address=10.0.0.0/8 in-interface=[/interface wireless find] dst-port=443 comment="Drop HTTPS From Clients to Clients"
add chain=forward action=drop protocol=tcp dst-address=10.0.0.0/8 in-interface=[/interface wireless find] dst-port=8291 comment="Drop Winbox From Clients to Clients"
add chain=forward action=drop protocol=tcp dst-address=10.0.0.0/8 in-interface=[/interface wireless find] dst-port=8728 comment="Drop API From Clients to Clients"
add chain=forward action=drop protocol=tcp dst-address=10.0.0.0/8 in-interface=[/interface wireless find] dst-port=8729 comment="Drop API-SSL From Clients to Clients"
Only problem is the [/interface wireless find]
On some sectors there is disabled virtual AP’s.
I do this for failover reasons, if one sector die all the clients can connect to a virtual ap then.
The [/interface wireless find] sometimes sets the interface to the disabled ap and not the enabled interface.
Any way to find only enabled wireless interfaces?
[/interface wireless find] returns an array of values (if multiple interfaces exist).
Either you get specific interface by name or you run :foreach to loop through all returned items.
why don’t you isolate clients? On APs disable “Default Forward”, on bridges use the same horizon.
Clients is isolated at the moment, sorry but I don’t understand what you mean by " on bridges use the same horizon."
The network is fully routed.
If there is two sectors for example 10.100.1.0/24 and 10.100.2.0/24.
I don’t want clients from 10.100.1.0/24 to be able to ssh/telnet ect to clients on 10.100.2.0/24, but I still need to have that access from the office.
I could set the IP services on the CPE’s but problem is, there is over 2000 of them out in the field.
So I thought by blocking connections from the users will be the best solution.
If there is a better solution please share.
Thanks mrz for the explanation how [/interface wireless find] works.
I am going to do all the sectors by hand so I can check IP services and If they are sending their daily backups.
How do clients get their IP?
I assign each radio their own fixed IP address in the subnet.
Those who require a public ip address gets a eoip tunnel to the main gateway.
Its fixed wireless installations.
Then there is dhcp and nat set up on the CPE’s
This should do the trick if all the sectors have one virtual-ap.
/interface wireless set [find interface-type=“virtual-AP”]
No I should just figure out how to make it not set to the vap or the ethernet.
I want to create a .vbs script that sets all the sectors when I run it.
Is it possible to to find wireless interfaces where there is registered stations ?
