'/interface/wireless/scan','=.id=wlan1', '=rounds=1'
I’m writing a script to get the result scan every 5s.
I use mikronode-ng but I think this is a problem RouterOS.
By sending the second command CPU lock in 100% it only happens if I send the parameter “rounds”.
When sending =duration=3 for example it does not.
I’m completely disconnecting and connecting again in the tests I’m doing.
if you are not using secure mode - you can sniff traffic and see what you send and what the router is replying.
Also, try one of the latest versions. I see no problems running that command using rounds.
I Use version 6.37 no secure.
Enviado de meu SM-G800H usando Tapatalk
I Found problem, was in api library, its solved.
https://github.com/f5eng/mikronode-ng/issues/17
