Interference from GSM sector antennas
Hi
I’d like to install a 5GHz sector antenna on the roof
of a hotel, as one end of a 6km point to point link.
Unfortunately there is already a mast with a trio of
GSM sector antennas on the this same roof.
Will this cause any interference ? I shouldn’t think
so because we won’t be on the same band.
yann
No.
thanks inox
We do sometimes have problems with GSM towers and powerfull FM stations …
do not put your antenna’s in front of the cellular antennas …
2.4 is a problem with GSM towers, evan at 100 meters distance . 5 ghz only if you are realy close <5 meters
With FM towers we sometimes need to use Toughcable pro, to reduce RF interference on cables.
I did even had once a melted cable du to RF power from a FM station, the Ferrites we put on the cable to block RF melted into the cable.
Wow, fascinating and eye opening
thanks Petzl
