Interference Problems
Hi ,
i’ve been struggling with interference situations of late. sometimes, signal strengh is good, around 67 but there is still high response time between client and AP. any helps on how to tweek wireless interfaces to solve these issues?
Freq used : 5GHz range
RouterOs : 2.9.50
Thanx
Just wonder know, are u using the licensed version or?
if you purchased the license, try to upgrade to RouterOS V4.13 and use the nv2 setting as it’s good to use in interference environment.
