Hi Forum.
I’ve have a little problem which I cannot solve by my self.
I’ve created my own firewall based on a mikrotik CCr1009.
I have created the following networks
LAN → 172.16.100.0/23
DMZ → 192.168.100.0/24
What I’m trying to is Accessing the servers in DMZ using FQDN. → test.example.com
If I used my IP-address for the server directly - I’m getting through to webinterface on the machine. but not using the FQDN
I’ve tried to set up static DNS for the host - but still not working
Flags: D - dynamic, X - disabled, R - regexp
# NAME ADDRESS TTL
0 test.example.com 192.168.100.50 1d
nslookup test.example.com – Gives WAN ip
ping test.example.com – Gives WAN ip
http://test.example.com → could not connect to website
How Can I make this work - so that I’m able to use FQDN from LAN to DMZ
P
