Hi all
As part of testing process before purchase, Mikrotik OS v4.15 was installed on server with 2 network interfaces, one of them was connected to Internet, other on LAN configured with static C class IP address. We wanted to test static routing.
I added 4 static routes to 4 different C class private networks over Cisco router on same subnet as Mikrotik (VPN links to remote locations) and expected that Mikrotik will send ICMP redirects to PC-s who had it as default gateway, but that didn’t happen. No traffic was going to remote locations from PCs.
After that I enabled DHCP server on Mikrotik and it started to work properly - sending ICMP redirects for routes it had entered, PC’s could connect to remote networks via Cisco router. Routing was working as it should.
In the end I disabled DHCP server on Mikrotik and it continued to send ICMP redirects.
Weird. Why did I have to enable DHCP server for Mikrotik to start sending ICMP redirects of his static routes? Not documented, searched trough web/forum/wiki … nothing relevant. I almost gave up on Mikrotik, colleague told me he had same problem and that he solved it this way.
Thanks, regards
Ivica
