Internet access at certain times
Hello, I would like how I can do to have Internet at certain times
I have a machine with a specific mac address, I would like this machine have internet
to 8hrs to 12hrs and 17:30 to 22hrs00, how do here?
Thank you for your prompt response
I have not used this feature yet, but you can set firewall filter rules with a time parameter.
add chain=forward action=drop src-mac-address=xx:xx:xx:xx:xx:xx time=00:00:00-08:00:00,mon
This rule drops access from that mac from midnight to 8am Mondays. Set the other time periods the same.
I do not know how to set this with all days. It wants a day of the week. ??
ok, thank you for the method but I had already found another method with Schudel, by creating a rule in ip-binding and each time I want the client have no connection I turn off just in ip-binding
is this also a good configuraiton
If the user of the computer does not have a user/password for the hotspot, that will work. If the user does, that will not stop it.
if you are using ip-binding, the computer/router/device must be behind a hotspot, correct?
ok, thanks
