Internet access to BTH/Wireguard
Have been trying to provide internet to wireguard after activating BTH so that i can connect remotely even when i have no internet at my remote location. Is there anyway/configuration that can provide internet to wireguard client remotely? I use starlink standard as my ISP.
Just a thought to start with...
And how do you think that wireguard on remote location will work without internet ?
@holvoetn so i need a guide to route traffic to provide internet access through wireguard since there is no internet at my remote location.
You will need to explain better your situation, wireguard is a (safe) tunnel over a connection.
If you don't have internet on the remote site, which kind of connection do you have to it?
@jaclaz I understand you, thanks for the clarification
I first wanted to put
"how do you drive a car without wheels ?"
Maybe that would have been more clear from the beginning ?
You need a working network connection for wireguard to work.
You don't need internet as such. You can perfectly have wireguard on an internal network as well with zero external access.
But you do need "some sort of" connection.
