Internet available via LAN but not via WLAN
Hi All,
I have recently set up a new VDSL internet connection at my house and am having a few issues connecting to the internet via WLAN. It is fine from a LAN device.
I have a Draytek vigor 130 modem that is used to connect to the internet via PPPoE (VDSL)
This modem has an IP address: 192.168.1.1 and has DHCP disabled (DHCP Relay to my Mikrotik routerboard).
This modem is connected to a 24 port unmanaged switch.
The unmanaged switch is also connected to Ethernet port 5 on my Mikrotik RouterBoard 951G-2HnD (IP: 192.168.88.1)
I also added a default route to my internet gateway and a masquerade NAT entry:
This seems to have been sufficient to connect to the internet via a LAN device.
However any devices connected to my WLAN can’t access the internet.
My Ethernet and my WLAN are both on the same bridge
WLAN devices can connect to both routers (192.168.1.1 and 192.168.88.1) just not to the outside world.
Apologies in advance if this is the wrong place for this, or if this has already been answered elsewhere :slight_smile:
Cheers,
Dan
