Internet network exchange on lost connection
On the Routerboard device model RB201 1iL-RM we have two WAN connections and a LAN connection. When it goes down the WAN1 internet connection must automatically switch over to WAN2. When the WAN1 connection is re-established the Router must return to the main internet connection, WAN1. How can I configure it? Is it possible to have a script already working?
Thank you.
Look here.
-Chris
I followed the guide but I can’t get it to work.
You have a backup file for this configuration that you can import.
Thank you so much
Fernando
With export command, copy and paste here your configuration (using hide sensitive option).
Regards.
model = 2011iL
serial number = 762507C3378A
add name=bridge1
set [ find default-name=ether1 ] name=ether1WAN1
set [ find default-name=ether2 ] name=ether2WAN2
set [ find default-name=ether9 ] name=ether9LANlocal
add name=pool1 ranges=192.168.1.2-192.168.1.254
add address-pool=pool1 disabled=no interface=bridge1 name=server1
add bridge=bridge1 interface=ether9LANlocal
add address=192.168.2.99/24 interface=ether1WAN1 network=192.168.2.0
add address=192.168.3.99/24 interface=ether2WAN2 network=192.168.3.0
add address=192.168.1.1/24 interface=ether9LANlocal network=192.168.1.0
add address=192.168.1.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.1.1
netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
add check-gateway=ping distance=1 gateway=8.8.8.8 routing-mark=ISP1
add check-gateway=ping distance=2 gateway=208.67.222.222 routing-mark=ISP1
add check-gateway=ping distance=1 gateway=208.67.222.222 routing-mark=ISP2
add check-gateway=ping distance=2 gateway=8.8.8.8 routing-mark=ISP2
add distance=1 dst-address=8.8.8.8/32 gateway=192.168.2.1 scope=10
add distance=1 dst-address=208.67.222.222/32 gateway=192.168.3.1 scope=10
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/system clock
set time-zone-name=Europe/Rome
There are changes to be made to the script sent
