Internet speed is really inconsistent
Got a microtik hAP ac2 a month ago and at the start it seemed to work great, as shown in the first photo. After a while it noticed it got a lot slower and it would only reach up to 100-110 mbps download and 800mbps upload. I tried resetting to factory settings and that seemed to do the trick for a short time but now its back to being really bad as shown in the second picture. Any clue why that might be?
This is not Clue/Cluedo game.
Provide relevant details, for example, why not?, the configuration?
Export the config but before post it remove private data with notepad or similar!!!
Move the IP from ether2 to bridge
which parts are the private ones?
and to change the ip from ether2 to bridge
add address=192.168.88.1/24 comment=defconf interface=ether2 network=
i need to change the bolded part to bridge?
for example serial number, pppoe username and passwords, wireless SSID and passwords
ok, I do the job for you, I hope someone can help you, I not see any wrong except for IP on ether2
# apr/28/2022 00:49:10 by RouterOS 6.47.10
# software id = VR0L-S598
# model = RBD52G-5HacD2HnD
# serial number = <CENSORED>
add admin-mac=DC:2C:6E:2D:C2:81 auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
    password=<CENSORED> use-peer-dns=yes user=<CENSORED>
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=<CENSORED> wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country=romania disabled=no distance=indoors frequency=\
    auto installation=indoor mode=ap-bridge ssid=<CENSORED> \
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik wpa-pre-shared-key=<CENSORED> \
    wpa2-pre-shared-key=<CENSORED>
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
/interface wireless access-list
add mac-address=<CENSORED>
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
    192.168.88.0
/ip dhcp-client
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=accept chain=forward dst-port=<CENSORED> in-interface-list=WAN protocol=\
    tcp
add action=dst-nat chain=dstnat dst-port=<CENSORED> in-interface-list=WAN protocol=\
    tcp to-addresses=<CENSORED> to-ports=<CENSORED>
/system clock
set time-zone-name=Europe/Bucharest
/tool mac-server
/tool mac-server mac-winbox
You can paste this directly on terminal:
set [find where address=192.168.88.1/24] interface=bridge
Or you can change interface on ip / address on winbox from ether2 to bridge
(because eterh2 is a bridge slave)
