Internet speed slow in router os 7.19 and up Hex refresh E50UG
internet speed and simulated internet speed in Mikrotik E50UG is very slow in new router os
i have tested speeds in router os 7.15.3 where the speeds are really good but in router os 7.19.1 , 7.19.2 or 7.19beta4 all have slow internet speed
the config is of an static IP from ETHER1 port and all the LAN devices are connected to other ports
while on router os 7.15.5 i get more than 800mbps on LAN devices same cant be said for 7.19+ on which i get upto 157mbps.
if there is anything else i could provide let me know,
sorry for bad english,
There is a known issue specific to the new Hex (your E50UG) and also the new Hex S affecting ether1, see:
If it works in 7.15.3 as expected, do not update to newer versions of RouterOS until the isssue has been solved in a new release.
Otherwise a workaround is to not use ether1 as WAN, but configure another port (let’s say ether2) as WAN.
Another mitigating factor may be using properly queues, see:
New firware chnage nothing in HEX refresh and HEX S.
So we must wait …
so i did some experiments and this is what i have found
i have downgraded to 7.15.3 and reset the device and setup the device and then upgraded to the latest 7.19.2 and it gives me more than 800mbps using ether1 as wan but setting up the hex refresh as new from 7.19.2 the speed gets stuck at 150~mbps using ether1
but i have to experiment using any port other than ether1 as wan one of my friend said that not using ether1 and using some other port as wan is much faster but i have to try it out my self
If this is 100% reproducible, I think MT support would be very interested in your scenario.
If you have the time to spare, you could make lots of people’s lives a bit easier :slight_smile:
also i swapped ether5 and ether1 for WAN
and speed now goes upto 950+ mbps using ether 5 as wan is amazing
