internet speed
Hi. When upgrading my network I bought a router E50UG. I noticed that wired clients are getting full bandwidth, i.e. 100/30 Mbps. On the other hand, clients connected wirelessly via acces points have a limited download bandwidth of 20 and upload remains 30 Mbps. Tested with different acces points but the result remains the same.
I restarted the router to default settings and still the same. Disabling the rules doesn’t change anything either.
What am I doing wrong?
anynameyouwish.rsc (5.9 KB)
What model of access points? The config is basically default so there should be no difference between wired or wifi clients based on the config.
So the issue is a the AP side…
Which access points are you using? Do they have a full Gbps link to the router or only fast ethernet (100 Mbps)? Are WiFi clients connected to 5 GHz or 2.4 GHz channels?
I tried on several access points: asus, openwrt, cisco and all had the same effect. Also, if the old router is connected I do not have this problem. Should access points have any special settings?
ISP router + any AP = :+1:?
E50UG + any AP = :-1:?
E50UG config looks like default configuration.
You APs need to be DHCP client.
Everything was rebooted and received the address from the correct router.
I ordered another E50UG router and received identical results.
Testing further I ordered hAP ac² and here all tests came out ok. The download speed is identical for clients connected directly and via access points.
Therefore, I suspect that something is wrong with the E50UG routers.
Suggest you send supouts to MT as possible bug reports.
