Internet stop working / DNS Issue
Hi all,
Don't know what happened but I've lost my internet connection, even when I try to update on "check for updates" the message is "could not resolve DNS name".
I didn't changed anything on my pc or at the TIK, but after that I've already tried to set same DNS on Tik and at the computer, still don't success.
[admin@MikroTik] > ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADC 192.168.88.0/24 192.168.88.1 ether1 0
[admin@MikroTik] > ip address print
ADDRESS NETWORK INTERFACE
0 ;;; defconf
192.168.88.1/24 192.168.88.0 ether1
[admin@MikroTik] > interface print
NAME TYPE ACTUAL-MTU L2MTU MAX-L2MTU MAC-ADDRESS
0 R ether1 ether 1500 1598 2028 C4:AD:34:A2:CE:24
1 lte1 lte 1500 AC:50:43:1A:EE:FD
[admin@MikroTik] > ip dns print
servers: 8.8.8.8,8.8.4.4
dynamic-servers:
allow-remote-requests: yes
max-udp-packet-size: 4096
query-server-timeout: 2s
query-total-timeout: 10s
max-concurrent-queries: 100
max-concurrent-tcp-sessions: 20
cache-size: 2048KiB
cache-max-ttl: 1w
cache-used: 23KiB
[admin@MikroTik] > ping 8.8.8.8
SEQ HOST SIZE TTL TIME STATUS
0 no route to host
[admin@MikroTik] > ping www.google.com
invalid value for argument address:
invalid value of mac-address, mac address required
invalid value for argument ipv6-address
while resolving ip-address: could not get answer from dns server
Just for giggles, on the subnet where this is occurring,
go to the ip dhcp server networks settings and replace the DNS server from 192.168.88.1 for example to 8.8.8.8
and see if you get connected.
Looks like you are not getting an IP Address on LTE. On your Quick Set page it is empty. And when you pinged 8.8.8.8, which you don’t need DNS to ping IP, it returned “ no route to host”.
You right, I was trying with different SIM cards and forgot about the APN, but as you can see now, It doesn’t works with IP too…
This was because the APN xD my bad, but now and already changed what you said about the 8.8.8.8 still doesn’t work and when I try to ping…
0 8.8.8.8 timeout
1 8.8.8.8 timeout
2 8.8.8.8 timeout
3 8.8.8.8 timeout
sent=4 received=0 packet-loss=100%
/export hide-sensitive file=myconfig
Download myconfig.rsc from Files and edit with your favorite txt editor. Post content.
model = RBLHGR
serial number = B7350B0AC1B9
/interface lte
set [ find ] mac-address=AC:50:43:1A:EE:FD name=lte1
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=ether1 name=defconf
add comment=defconf interface=ether1 list=LAN
add comment=defconf interface=lte1 list=WAN
add list=LAN
add address=192.168.88.1/24 comment=defconf interface=ether1 network=
192.168.88.0
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment="defconf: masquerade"
/system clock
set time-zone-name=Europe/Lisbon
/tool mac-server
/tool mac-server mac-winbox
I don’t see a dhcp client.
/ip dhcp-client add interface=lte
The only other odd thing is a blank interface-list-member.
Well just turn it on the TIK and now It’s working…WTF? Didn’t change anything on config or position of the tik…
It was most likely the use of Quickset after you had already made changes. Quickset relies on basic scripts to make the changes and if you make changes outside of Quickset, it has know way allowing for your changes. And there are other instances of Quickset just being broke. If can avoid it using it, do so.
Hi all,
I have had the exact same issue and it has been two days since it has not been working. Is there any action I can take or do I just have to wait and hope that it will start working?
