Internet volume used in month
Is there is any way to set mikrotik such it save the volume(amount)(value in GB) downloaded from wan port after 30 days
Actually my target is
I want to can see what amount of my INTERNET is used in month.
you need to use some separate billing solution, either based on VPN accounting, or using NetFlow data for those stats
