So…
You whent out and picked up one of those new wireless interface cards…
Ala SR71 series…
I picked several of thiese up…
So here it goes…
If you take a “freah router” and install 4.0B4 and some of the new SR series cards
the card will show up in the system/resources, but NOT in the wireless interfaces.
This looks to be a bad day…
Not all is lost !!! Follow me down the rabit hole, and you will find wonderland…
- Install 3.28 with all standerd packages.
- Reboot the router.
- Upload the 3.28 “Wireless-test” package and via winbox, reboot and let the package install.
- Wait for reboot to complete. (NO the card wont show yet…)
- Upload the 4.0b4 package set (I used the single file)
- Reboot and let the router come ready.
- Make sure the router has the new license format license file and reboot if needed to apply the new format.
Afer reboot if needed, Take a look at the wireless menu… And welcome to wonderland…
The card is there !!!
Dont ask me how it got there !!
You cant do a freah install of the 3.28 with the wireles-test package, it NEEDS to see the wireless -test package “upgrade” the existing package…
Then wnen 4.0b4 installs it reads the 3.38 ini files and loads the card and it becomes available..
