Hello All,
First post on this forum to have some advice.
We’re actually implementing mikrotik as an internal router, managing some vlan on a trunk then 2 pppoe-client.
Each vlan as assigned isp and some vlan must speak between them.
Consedering this setup :
http://wiki.mikrotik.com/wiki/Manual:Interface/VLAN#InterVLAN_routing
But in our case
[admin@RTR] /interface vlan> print
Flags: X - disabled, R - running, S - slave
# NAME MTU ARP VLAN-ID INTERFACE
0 vlan10-LAN1 1500 enabled 10 ether5-LAN1
3 vlan30-LAN1 1500 enabled 30 ether5-LAN1
[admin@RTR] /ip address> print
# ADDRESS NETWORK INTERFACE
0 172.18.21.250/24 172.18.21.0 vlan10-LAN1
3 192.168.112.250/24 192.168.112.0 vlan30-LAN1
For this purpose we actually use only the vlan10 & vlan30 interface
[admin@RTR] /interface pppoe-client> print
0 name="pppoe-out1-ML" max-mtu=auto max-mru=auto mrru=disabled interface=ether10-ML
user="" password="" profile=default keepalive-timeout=60 service-name=""
ac-name="" add-default-route=no dial-on-demand=no use-peer-dns=no allow=pap,chap,mschap1,mschap2
1 name="pppoe-out2-LAG" max-mtu=auto max-mru=auto mrru=disabled interface=ether9-LAG
[admin@RTR] /ip firewall mangle> print
0 chain=prerouting action=mark-routing new-routing-mark=M passthrough=yes
src-address-list=VLAN10 log=no log-prefix=""
1 chain=prerouting action=mark-routing new-routing-mark=LAGpassthrough=yes
src-address-list=VLAN30 log=no log-prefix=""
[admin@RTR] /ip route> print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - osp
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 S 0.0.0.0/0 pppoe-out1-M 10
1 S 0.0.0.0/0 pppoe-out2-LAG 10
4 DC 172.18.21.0/24 172.18.21.250 vlan10-LAN1 255
12 DC 192.168.112.0/24 192.168.112.250 vlan30-LAN1 255
Also, There are the routing marks on theses routes but not appear in print.
[admin@RTR-SF2I-02] /ip firewall nat> print
15 I ;;; pppoe-out1-M
chain=srcnat action=masquerade routing-mark=M out-interface=pppoe-out1-M log=no
log-prefix=""
16 I ;;; pppoe-out2-LAG
chain=srcnat action=masquerade routing-mark=LAG out-interface=pppoe-out2-LAG
In this setup (during this redaction all ports were not plugged) each lan can reach internet but can’t communicate between them.
If we disable the #0 & #1 routes lan aren’t able to reach internet but can communicate with each other.
The issue is not a firewall issue, as we disable all firewall rules it remain the same.
We believe it’s routing probelm because the ping by router or client can’t go to the destination.
We also tried to do a masquerade rule per lan (with specified address list) with corresponding internet gateway.
After reading of some posts, some clues can be involved like doing a mangle rule to route traffic through their specific isp or specifiying a prefered source for static route w & w/o routing mark.
but the concept that i missunderstand why the default routes (with & without routing mark) seem to override the local routes, same when upping metric.
If somebody can get us in the righ direction.
best regards.
