Intervlan forwarding delay? Slow SSH/https across vlans
Hi There!
I recently got an rb4011 to use as my edge and have gotten almost everything working as I would like it, but cannot seem to figure out this one particular issue. Honestly I am not sure if this is more of a proxmox issue or if it is a networking issue, but the issue presented itself when switching over to using Mikrotik for the edge instead of the Ubiquiti edgerouter :frowning:
Vlan 11 - Lab LAN
Vlan 21 - Home LAN
I am doing this from the frame of reference of being on the Home LAN.
The proxmox hypervisor bridge has interfaces on both the Home LAN and the Lab LAN, and if I SSH the IP of the interface on the same network there isn’t a delay.When trying to ssh from my Home LAN to one of my proxmox hypervisors bridge interface on the Lab LAN, there is a 10-15 second delay before it responds. What makes things weird is that there doesn’t seem to be a delay when SSHing to a VM on that same example hypervisor whos interface is also on that bridge, which leads me to believe this is somehow a proxmox issue. I am just hoping someone has some familiarity that can set me straight.
An example of the network interface on one of the proxmox hosts:
auto vmbr2
iface vmbr2 inet static
address 192.168.0.44/24
bridge-ports eno1
bridge-stp off
brdige-fd 0
bridge-vlan-aware yes
bridge-vids 2-4094
auto vmbr2.11
iface vmbr2.11 inet static
address 10.1.0.4/24
gateway 10.1.0.1
auto vmbr2.21
iface vmbr2.21 inet static
address 192.168.1.35/24
I don’t know what configs on my rb4011 would be relevant to this as I’m not sure if this is a layer 2 issue or if this has something to do with the default fasttrack rules. Any help would be appreciated and any information I can provide will be done.
First thing that comes to mind is the typical reverse DNS query most linux distros do when accessed via SSH. If it cannot reverse-query the source IP, you may experience this delay.
Posting the 4011 config will definitely help.
agreed by the 100%
check /etc/ssh/sshd_config of your containers …vm’s whatsoever …
#PermitUserEnvironment no
#Compression delayed
#ClientAliveInterval 0
#ClientAliveCountMax 3
PermitRootLogin vielleicht
UseDNS no
#PidFile /var/run/sshd.pid
#MaxStartups 10:30:100
#PermitTunnel no
#ChrootDirectory none
or even better; setup full-functional dns (including reverse-dns) for your entire network ..
You guys hit the nail on the head, my Powerdns recursor wasn’t forwarding the reverse dns lookups!!! I’ve been trying to figure this out for like a week!
