InterVLAN Routing CRS125-24G-1S-RM
Hi everybody,
I was wondering if the model in t the subject does inter vlan routing by itself. All tutorial/wiki founded talk about switch + trunk + router for inter vlan routing (router on a stick mode). I would like to do it just with the switch, not with the router. Is it possible to do it?
I have created 2 vlan interfaces in 2 different subnets but they cannot ping each other
Regards
Federico
admin@MikroTik] > ip address print
ADDRESS NETWORK INTERFACE
0 172.31.255.2/24 172.31.255.0 VLAN_MKSEDE
1 192.168.1.39/24 192.168.1.0 VLAN_UFFICI
[admin@MikroTik] > interface vlan print
Flags: X - disabled, R - running, S - slave
NAME MTU ARP VLAN-ID INTERFACE
0 R VLAN_MKSEDE 1500 enabled 50 BR_MK_SEDE
1 R VLAN_UFFICI 1500 enabled 30 BR_UFFICI
[admin@MikroTik] > interface bridge
calea host port add disable enable find print set
filter nat settings comment edit export monitor remove
[admin@MikroTik] > interface bridge print
0 R name="BR_MK_SEDE" mtu=auto actual-mtu=1500 l2mtu=1588 arp=enabled
mac-address=E4:8D:8C:84:66:C9 protocol-mode=rstp priority=0x8000
auto-mac=yes admin-mac=00:00:00:00:00:00 max-message-age=20s
forward-delay=15s transmit-hold-count=6 ageing-time=5m
1 R name="BR_UFFICI" mtu=auto actual-mtu=1500 l2mtu=1588 arp=enabled
mac-address=E4:8D:8C:84:66:CB protocol-mode=rstp priority=0x8000
2 R name="OUTSIDE_FIREWALL" mtu=auto actual-mtu=1500 l2mtu=1588 arp=enabled
mac-address=E4:8D:8C:84:66:CD protocol-mode=rstp priority=0x8000
[admin@MikroTik] > ip route print
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 192.168.1.1 1
1 ADC 172.31.255.0/24 172.31.255.2 VLAN_MKSEDE 0
2 ADC 192.168.1.0/24 192.168.1.39 VLAN_UFFICI 0
The short answer is no…MikroTik switches do not route between VLANs like a Cisco switch with SVIs where the traffic is wire speed.
CRS switches must use the CPU to route between VLANs.
http://wiki.mikrotik.com/wiki/Manual:CRS_examples#InterVLAN_Routing
