intervlan routing SW L3
HI i would like to know if i can replicate this example made with CISCO s3 switch with mikrotik technology
i post the link :
https://www.youtube.com/watch?v=EhB2hM6j1oQ&t=302s
i would like to use one SWITCH L3 in a ring topology with one switch acting as DEFAULT GATEWAY for hosts.
i try to explain
i have SW1 SW2 e SW3 in a ring topology SW1 act as a default gateway.
i try to create a bridge in SW1 with 3 sub interface, VLAN10, VLAN30, VLAN99 (for management) i have done the vlan table (TAGGED UNTAGGED ) I have set the PVID in access port, i have create the IP and assigned to sub interface in SW , i’ve activate vlan filtering on sw1, sw2, sw3 bridges, i created the 0.0.0.0/0 root for SW2 and SW3.
the resut. i can ping from switches but if i try in gns to give an address to pc the pc can’t reach SW1 sub interface (default gateway).
can you help ?
