InterVlan routing with Mikrotik CRS326-24G2S+RM switches only
Hi everyone!
We are planning to use Mikrotik CRS326-24G2S+RM switches at one of our projects, and need to clarify if these switches support InterVlan communication/routing.
I have googled it and got some mixed answers, so wanted to be sure that this is supported.
Also if supported, are there any drawback with this configuration.
Thanks!
Switch Details: Cloud Router Switch 326-24G-2S+RM with RouterOS L5, 1U rackmount enclosure
InterVLAN routing is possible using this switch BUT performance will be slow because this switch model cannot Route at line rate. So if you need performance I would suggest that you use this model as a switch – where switching performance is excellent — and select another model as your Router.
