Intruder ? 912 basebox
Hello ..
I have this AP client “bobo” and I don’t know who or what he is .. please take a look at the image attached ..
How can I block him ?
Regards ..
Change your WAP2 password.
Or add the client to the access list and disable it’s access. But that only helps if they do NOT change their MAC address.
Maybe think about management protection frame feature.
Thanks your replay is really useful
Thank you I will
It helps even if he change the mac. Just disable Default Authentificate in the wireless tab. In this mode, only the stations added in Access List will connect.
