Hello. I use certificates for ovpn and also use the revocation service inside the mikrotik. I normally do this by adding the corresponding URL. (usually http://“router ip”/crl/1.crl). The problem is that I try this with a new Routerboard RB750gr3 and it always show invalid. I have then decided to downgrade to 7.2.3, and only after downgrading and also resetting the config it started to work. On strange thing I noticed is that after that I can upgrade to 7.5 and still works. Does anyone have an idea why this is happening with 7.5 and how to correct it?
Thank you
