Invalid Ip Address on PPPoe-Server
I have an Routerboard CCR1036-12G-4S RouterOs 6.2 firmeware 3.09, but few errors are happening on PPPoE connections.
Some connections are in state “DI” in ip address.
Somebody what know can are happening?
PS: In attach are the print of screen.
Thanks,
Tonni Teles
Same problem here! Very random and it seems to happen with one user at a time only on my router.
If you kick the user out, another user could connect to this “bad” slot.
I also notice the following: All my users are RADIUS authenticated, and normally the PPPoE interface must show “DR” next to the interface name. The users with the invalid address only show “D” with no “R”, although they are authenticated over RADIUS and not through the local “secrets”.
Any help from mikrotik support?!
I have the same problem described here: http://forum.mikrotik.com/t/invalid-address-on-pptp-server-routeros-6-x/67828/1
Could somebody please let us know when this bug will be fixed?
Thank you
I have the same problem with invalid IP in MK as pppoe server.
I am using CCR1036 and ROS > 6
Hey MK team? Help us!
