Hi all!
When I create an IPSEC policy, it goes into Invalid status. The subnet does not overlap, everything is exactly the same on the remote side and the policy has the correct status.
I noticed that if you change the subnet mask, for example, to /26, then the policy immediately changes the status from Invalid to normal.
Why is that?
ROS Version 7.6
