Hi everyone,
I realized that my mikrotik router 732 does not have the multicast feature, therefore i tried to install the multicast package. I copied the package to the router and received this error: “Could not change the key - invalid key”.
What is the problem and how can i rectify that?
Thanks for the help.
Regards
drag the package into the files menu, not anywhere else.
Hi
thanks for the reply. I did that, it actually shows is copying but the error come out halfway through the copying..
What happen?
regards
Try to transfer using FTP then
Hi
thanks for the reply..
I transfered into the power router, then I did a reboot, the multicast package still not installed.. I read the log file, it says the package cannot be installed.. No further elaborations.
What is the next step I can do?
Regards
does the version number and package type match those that you have in “/system package print” ?
Hi
I am running on routeros-x86 version 3.3. I downloaded the multicast package 3.3 it also didn’t help.
What can I do next? Thanks
regards
Hi
is it possible to reset everything to factory default and install a new os that contain the features I wanted or something?
Hard reset or something?
Use Netinstall or CDinstall and use latest RouterOS v4.9 all packages included and it should fix it. Key will be kept if you won’t manually reformat it, just use the official installers.
Hi
I have difficulty using the serial console..
I connected to the serial port, but nothing comes out when I off then on my switch again.
Why ia or so? I tried a few times alr..
