invalid password for user <>
Dear Support,
I have an issue regarding config radius between cisco router and radius server (Mikrotik), unfortunately after try to configure as the same instruction from Mikrotik it still not working.
here is the configure for cisco router:
aaa new-model
aaa group server radius testing-radius
aaa authentication login default group testing-radius local
aaa authorization console
aaa authorization exec default group testing-radius local if-authenticated
aaa session-id common
and for radius server:
  1. Create router IP address 10.0.0.1 share secret xxxxxxx
  2. Create profile
  3. Assign user to the profile
After done above, I try to use ssh login to cisco router but unfortunately it shown invalid password for user all the time.
I can see the session from radius as well it shown that invalid password.
Is there anyone face this issue before please kindly share your experience ?
Please Mikrotik Support this issue as i will purchase the new license for our data center if Mikrotik working well we will replace the existing radius.
Thanks you,
Rady
