Invalid value for argument address : RB4011
Hi everyone I need help.
I have ISP router that set to bridge mode , static IP credentials and Mikrotik RB4011iGs
I already set Static IP in eth1 in address list, ISP DNS, Ip routes and Nat yet I cant connect to the internet also giving this error when pinging any website.
I contacted our ISP provider yet there is no problem when testing directly into a computer. but in my Mikrotik router couldn’t even connect to the internet
I also change the DNS yet it wont work.
I change the IP Static to x.x.x.x here for privacy
add name=WAN
add name=LAN
add bridge=magnumbridge interface=ether3
add bridge=magnumbridge interface=ether4
add interface=ether1 list=WAN
add interface=magnumbridge list=LAN
add address=x.x.x.x/26 interface=ether1 network=x.x.x.x
add address=192.168.1.1/24 interface=magnumbridge network=192.168.1.0
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1 \
    netmask=24
set query-server-timeout=5s servers=161.49.49.49,161.49.48.48
add distance=1 gateway=ether1 routing-mark=1_subnet
add disabled=yes distance=1 gateway=x.x.x.x routing-mark=1_subnet
/ip route rule
add action=lookup-only-in-table src-address=192.168.1.0/24 table=1_subnet
/ip service
This was already a long time ago, I forgot to close this thread and I won’t delete it in case someone has the same problem as mine.
The problem was in the ISP provider that it needs to match the VLAN ID to that I can UP the internet connection, well I’m very busy at that time I let them do their job to configure on their side because ISP Tech support sucks getting 2 weeks’ time before they to configure my request.
