hi,
is there anyway to connect an iphone to mikrotik over IPSec(Cisco) ?
thanks
hi,
thanks
Of course there is:
http://wiki.mikrotik.com/wiki/Manual:IP/IPsec#Road_Warrior_setup_with_Mode_Conf
-Chris
Thank you , That was very helpful
but the iPhone traffic not going trough the router
on the same router PPTP connection is ok
what can I do for it ?
and what about Authentication server ?
Radius support ?
Mikrotik does not support IKEv2. My suggestion is openwrt+stronswan for IKEv2
The best working VPN surely is L2TP/IPsec.
Have a look at my post here:
http://forum.mikrotik.com/t/super-easy-vpn-for-macos/102865/1
-Chris
I know L2TP is better ! and I already have a L2TP VPN server and its works perfect !
I also have a Strongswan with IKEv2 too (works perfect on iOS & all devices)
but I want a IPSec-Cisco VPN Server on Mikrotik
is that possible to send all iOS traffic over IPSec-Cisco to the mikrotik router ?
thanks
I have got a problem with mikrotik ip sec for Apple ios
the log :
Failed to get valid proposal
Failed to pre process ph1 packet(side :1,status : 1)
phase1 negotioation failed
what shall i do ?
I have gor problem with mikrotik ip sec for Apple ios
the log :
what shall i do ?
