IOS https hotspot
Apple IOS just came out a few days ago with an update so I am not sur eif this is part of the issue or not.
On ROS 6.42 my https hotspot works fine no cert errors everything is perfect. As soo as I upgrade it to ROS 6.48 IOS device connect wont redirect get connect no internet error and then if I try and surf to force the page i get my certs are mismatched. Android devices work fine. ANy thgoughts
Found the answer and it worked had to add that json file
http://forum.mikrotik.com/t/captive-portal-ios-16-0-2-issues/161110/8
