why do you put those things in walled garden? this will make hotspot not work.
apple checks those sites, and if it detects hotspot, login page is opened. if you put them in walled garden, iphone thinks that you have internet, and doesn’t open login.
another suggestion is if you use DNS name in the Hotspot configuration then if you use just name for example, company, then you need to ad domain, for example, company.com
do this only if you know what you are doing and why the manual gives this example for people who do not want to see the login page, because they need the user to manually open browser and do something
I am Eduardi’s friend, using the same network and also having the same problem. i only updated my ipad yesterday with the ios 8.1 (i was using ios 7.1.2 without any kind of problem with our network) and for my surprise this was the result…Blank page instead of the login one. Let’s see if we can figure out how to solve this problem…
