"IoT" WiFi with VLAN - no traffic
I have a relatively simple (lol) setup, where my ISP’s router is my egress, and I have a Mikrotik hAP ac and a Raspberry Pi connected to it.
The RPi is my DNS (PiHole), but everything else is behind the Mikrotik.
I am trying to create a separate wireless network for IoT devices; the network has its own VLAN (32).
The RPi has
  • the default interface connected to the ISP router
  • VLAN4 that lets it talk to the “defconf” network
  • VLAN 32 is supposed to let it talk to the IoT network.
On the Mikrotik, in short (and I’m pasting my redacted /export hide-sensitive below)
  • the Virtual WLAN has PVID32
  • there is a VLAN (from /interfaces) configured for the ingress from the RPi and
  • a bridge tying them all together
  • addresses are configured, and DHCP server too.
And yet, while the RPi is able to ping the hAP (on the VLAN32 address) and get an address from the DHCP on VLAN32, devices on the “IoT WLAN” are not able to get an IP address. Windows gives me the 169.254.x.x address, Android just gives up.
The weird part is that I do see from /interface bridge host print, devices connected to the IoT WLAN with the correct VID. They just can’t figure out how to talk to the hAP, I guess..?
I tried (re)configuring this multiple times, including every possible iteration (including the stupid ones) of “accept all” and “accept only tagged” frames, and “tagged” and “untagged” interfaces.
I can’t understand what I’m doing wrong, does anybody spot anything that I’m missing?
Thanks!
[admin@MikroTik] > /export hide-sensitive
# model = RouterBOARD 962UiGS-5HacT2HnT
add admin-mac=AA:BB:CC:DD:EE:FF auto-mac=no comment=defconf name=bridge
add ingress-filtering=yes name=bridge_home_devices pvid=32 vlan-filtering=yes
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=wifi wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid=wifi wireless-protocol=802.11
/interface vlan
add interface=bridge name=mgmt vlan-id=99
add interface=ether1 name=vlan_pihole_default vlan-id=4
add interface=ether1 name=vlan_pihole_home_devices vlan-id=32
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik
add authentication-types=wpa2-psk management-protection=allowed mode=\
    dynamic-keys name=home_devices supplicant-identity=MikroTik
/interface wireless
add disabled=no hide-ssid=yes mac-address=11:22:33:44:55:66 master-interface=\
    wlan1 name=wlan_home_devices security-profile=home_devices ssid=wifi-dev \
    vlan-id=32 vlan-mode=use-tag wds-default-bridge=bridge_home_devices \
    wps-mode=disabled
add name=dhcp_unknown ranges=192.168.88.100-192.168.88.199
add name=known_devices ranges=192.168.88.4-192.168.88.99
add name=dhcp_homedev ranges=192.168.88.200-192.168.88.254
add comment="Home devices addresses" name=homedev_pool ranges=\
    192.168.32.2-192.168.32.254
add address-pool=dhcp_unknown disabled=no interface=bridge name=defconf
add address-pool=homedev_pool disabled=no interface=bridge_home_devices name=\
    dhcp_home_devices
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge comment="PiHole Access" interface=vlan_pihole_default
add bridge=bridge_home_devices comment="Home Devices Bridge" interface=\
    vlan_pihole_home_devices pvid=32
add bridge=bridge_home_devices interface=wlan_home_devices pvid=32
/interface bridge vlan
add bridge=bridge_home_devices untagged=\
    wlan_home_devices,vlan_pihole_home_devices vlan-ids=32
add interface=bridge_home_devices list=LAN
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
    192.168.88.0
add address=192.168.0.7/24 interface=ether1 network=192.168.0.0
add address=192.168.99.1/24 comment="Management access" interface=mgmt \
    network=192.168.99.0
add address=192.168.32.1/24 comment="Home Devices Gateway" interface=\
    bridge_home_devices network=192.168.32.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
add address=192.168.32.0/24 comment="Home devices network" dns-server=\
    192.168.32.2 gateway=192.168.32.1 netmask=24
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.2 gateway=\
    192.168.88.1
set allow-remote-requests=yes servers=192.168.0.2
/ip dns static
    established,related,untracked
    invalid
add action=accept chain=input comment="Allow DNS (UDP) to PiHole" \
    dst-address=192.168.88.2 dst-port=53 in-interface=bridge_home_devices \
    protocol=udp
add action=accept chain=input comment="Allow DNS (TCP) to PiHole" \
    protocol=tcp
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add distance=1 gateway=192.168.0.1
add comment="Route traffic to PiHole on bridge_home_devices (VLAN 32)" \
    distance=2 dst-address=192.168.32.2/32 gateway=ether1
add comment="Route traffic to PiHole on default net (VLAN 4)" distance=2 \
    dst-address=192.168.88.2/32 gateway=ether1
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/tool mac-server
