I’m struggling with creating a script capable to export one of my static firewall Address Lists, named ssh_blacklist, to a .rsc file. I tried doing so with:
/ip firewall address-list print where list=“ssh_blacklist” ; export file=ssh_blasklist.rsc
Why do you like to export it?
If it is to examine the address, you can use send log hits to Syslog.
I do have black list for any trying a blocked port on my router. If you enter this log, router sends a message to my Syslog server (Splunk)
In Splunk I can see all IP address who and when they got in the log.
Here you can see how has tried to access my RDP, but ended are in a block access list.
See my signature for more info.
There are several ways to do this and I have written a backup and restore especially for interchanging between different routers. The focus is on keeping the filesize as low as possible.
It is close to RC and I was distacted by other projects so it went down the pile of other things. If you want you could help me with testing.
You can select one address-list at the time and that is a limitation as there is no way to restore dynamic entries without a timeout. But you can ignore them on restore so that they are kept on the target router.
It creates RSC files, importing those is simple and easy to be automated, that also apply to the backup.
