Hello!
I have an issue with my Router RB953GS-5HnT. I wanted to change IP address and allow my PC to connect to “Winbox” via Wi-Fi by using IP address. After I set IP address to my desired one and set up Wireless (used Mikrotik first-time-configuration manual), I wanted to connect to my router by IP address using WiFi. The problem is that, on “Winbox” it does not find my router but thrue MAC address it is possible to join even though I can not see it. When I try to join with my desired IP address (set in IP - addresses), it does not find router and is unable to connect to it.
I have tried many option, but can’t find a solution. What could be a problem? What have I done wrong or is it just some problems with my configuration?
