ip address to me
Hi All,
I’m trying to find a partner who can provide me an ip address. The ip address won’t be in EU and USA, and you can route this to a vpn channel (for example pptp, or any other with mt). Please help me.
(I know, how does it work, and I have an own address space. Important that if anybody locate in ripe.net, it is not in EU and USA.)
Thanks.
gyoztes
We can do this, but we are in the US.
Thanks Changeip! But the substance: if anybody check it on ripe.net, it seems it is not in the USA or EU. It is possibe with you?
We can do this, we are in Bosnia. However it depends what you want to do with it and how much bandwidth is required.
Hi cabana,
thanks! the bandwitdh will be minimal, it depends on you (for example 1 mbit/s?). I won’t be use it for real services, i just like, that it will be foreign country.
when will we try it? :slight_smile:
gyoztes
I can’t finish this project, because cabana haven’t answer. Can anybody help me?
