IP Address
Hi every one
Here the IP address is static or dynamic
add address=10.1.1.1/32 interface=ether1 network=172.16.1.1
Not enough info about the context.
Based on what is provided: please think for 5 minutes.
If you DEFINE the address as FIXED in config, what do you think it will be ?
Tip: dynamic is most likely not the right answer.
And why the mismatch between subnet of address and network ?
How can DEFINE the address as FIXED?
This is a rhetorical question:
Sounds like a knowledge question not an MT question?
If you have a question about an MT device, please ask it.
What is an IP address - https://www.kaspersky.com/resource-center/definitions/what-is-an-ip-address
What is the difference between a static or dynamic IP address ( one doesnt change the other does ). - https://www.avast.com/c-static-vs-dynamic-ip-addresses
You can always change the address manually every 5 minutes.
Then it’s also dynamic. No ?
Oh … that’s not the definition of dynamic ?
<pffff …>
