IP ALLOCATION USING HOTSPOT
Hye All
Scenario is my LAN1 Port Network has ip of 192.168.100.0
WAN is connected to 192.168.1.1 Router
On LAN i have configured HOTSPOT for authetication ip is allocated to user and pool is from 192.168.100.1 to 192.168.100.253.
My Question is as users are increased from and more ips are required to be allocated after 192.168.100.253 what to do???
Possible solution may be using the remaining ports with different network scheme and HOTSPOT but there definitely all ips will be consumed as Network will expand.
Please guide me in this scenario.
Thanks and Regards
Shariz
You have the function of next pool in your ip pool configuration, once all ips are used from first pool it will assign from next pool ! and so on.
