IP and Routing: SFP GPON Module WebUI access hmm
I need to make logon on a web gui off my Gpon SFP module. My bridge has 192.168.88.0 network while the SFP module has 192.168.1.1 ip address.
The gpon module is powered and working and I'm able to link to my ISP network, but i dont have access to sfp.
here's the config:
oct/11/2024 15:53:59 by RouterOS 6.48.7
software id = FJI9-4JNV
model = RB760iGS
serial number = HF0096A956H
add admin-mac=78:9A:18:47:F6:6F auto-mac=no comment=defconf name=bridge
/interface vlan
add interface=sfp1 name="vlan 3505" vlan-id=3505
/interface pppoe-client
add add-default-route=yes disabled=no interface="vlan 3505" name=pppoe-out1 password=MHtD7fJzAzE use-peer-dns=yes user=77666787787
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf disabled=yes interface=sfp1
add bridge=bridge interface=ether1
/interface detect-internet
set detect-interface-list=all
add interface="vlan 3505" list=WAN
add interface=sfp1 list=WAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=192.168.1.1/24 interface=sfp1 network=192.168.1.0
/ip dhcp-client
add comment=defconf interface=sfp1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=forward dst-address=192.168.1.1 in-interface=sfp1 out-interface=all-ethernet protocol=tcp src-address=192.168.1.1
/system clock
set time-zone-name=Europe/Moscow
/system identity
set name=RouterOS
/tool mac-server
/tool mac-server mac-winbox
please help(((
I would try removing the sfp1 from bridge (as opposed to leaving it there disabled) but it may be unrelated:
its dont work((
Shouldn’t the address be something other than 192.168.1.1? Maybe .2?
I dont know i’m just new at this
Then I guess that is the problem since the first address of a subnet is mostly reserved for the gateway, i.e. the GPON
i have another question, how to export configuration of mikrotik..?
terminal
/export file=anynameyouwish
File will be located in Files, you can move it to your computer.
One way is the aforementioned one, another way is to create a backup file through the Files menu whose content you cannot view, edit, etc. because it’s a binary file
Backup is not export config :smiley:
thank for your help!! im just reset configuration and all works!!
thanks!
Complete tutorial here:
http://forum.mikrotik.com/t/forum-rules/173010/1
