Hey Community Members’
I hope you are doing well. Recently I start observing an issue related to ARP, I have Tenda 03 device configured as AP and 8 Clinets are connected with as Stations. Router is configured as PPPoE. The problem is that after some time I start getting timeout from my Tenda o3 device IP Address 192.168.15.12 and all associated client devices as well. I found that ARP is not completing on Router and I have to unplug the Tend o3 LAN cable from the switch after plug the cable it start working again. ARP Screen shot is attached, please review and advise.
Update your mikrotik device just in case and then add a static arp entry for your tend AP…
if it’s only 1 of 8 failing, I would be looking AT that failing ap. Is it up-to-date and so on…
