IP (cam), Phone Home!
As part of my new church network, I’m installing IP security cameras. So far I’ve picked out four HikVision PTZ cams, two for indoor and two for outdoor. One is already in and is working fine.
My area of concern here is the many reports about low-end Chinese IP cameras “phoning home” to China without their owners’ knowledge. I’d like to restrict that as much as possible. I’ve never worked with VLANs before. My router is an RB3011 and my main switch is a NetVanta 1534 PoE which should be able to be configured to support multiple managed networks, if I can ever figure it out (We received it used and I haven’t managed to reset it to factory defaults yet to be able to regain admin access).
The cameras need to be able to see the main server, which is also the surveillance controller. It has dual LANs, so if necessary I can set one of them up strictly for surveillance. I’d prefer, though, to be able to use the dual ports for network redundancy. One of the cameras I may, in future, use for live streaming video of church services, so it should be able to see the PC which is running the streaming software. That should be it, save for admin access from my laptop and possibly the pastor’s PC. I’d prefer that the cameras not have access to IPv6 at all, although I do want to enable IPv6 service on the remainder of the network.
What’s the best way to accomplish all of this?
1 way around this:
Set up a firewall rule blocking forwarding from the camera out of your WAN interface.
When you need to view the cameras remotely, set up allow rules to the chosen WAN destinations and place them above the drop rule.
Another more brutal way;
If the remote surveillance is done purely form the main server then you can remove the GW from the cameras (assuming same LAN) as they wouldn’t necessarily “need” internet access.
How can I block IPv6 access from WAN to some more vulnerable devices (IP cameras, IoT, maybe VoIP phones) while leaving it open to systems (server, computers) which have a firewall which can be readily configured and monitored?
