I have an android phone running IP Webcam on wifi @ 192.168.88.253:14356
I can access it’s web interface via local address over LAN.
I’m trying to make it accessible through internet.
I have added
chain=dstnat action=dst-nat to-addresses=192.168.88.253 to-ports=14356 protocol=tcp
dst-address=*public-ip* dst-port=14356 log=no log-prefix=""
When I try to access it through public-ip:14356 only 6 packets are transmitted through the rule, and I get connection timeout in the browser.
This is my config compact:
# dec/25/2019 09:12:43 by RouterOS 6.46
# software id = N0HZ-JW7A
# model = RB951Ui-2nD
# serial number = *SERIALNO*
add admin-mac=*MAC* auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 use-peer-dns=yes user=\
*USER*
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=2 band=2ghz-b/g/n channel-width=20/40mhz-XX \
country=hungary disabled=no distance=indoors frequency=auto frequency-mode=\
regulatory-domain installation=indoor mode=ap-bridge ssid=2021 wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys \
supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
set discover-interface-list=none
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.113 client-id=1:0:26:b9:a:25:f7 mac-address=00:26:B9:0A:25:F7 server=\
defconf
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept established,related,untracked" \
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" \
dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=\
!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy" ipsec-policy=\
in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy" ipsec-policy=\
out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=\
established,related
add action=accept chain=forward comment="defconf: accept established,related, untracked" \
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none \
out-interface-list=WAN
add action=dst-nat chain=dstnat dst-address=*PUBLIC-IP* dst-port=14356 protocol=tcp \
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Budapest
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
