Ip cloud and dual wan
I have a small issue or maybe more a feature request…
I have a site with dual wan load balancing and using the ip cloud service
could I select from which interface I want the ip cloud to get the wan ip? or even better could there be added a multiple interfaces option and have a hostname per wan interface?
i have the same problem with customers with pcc that i combine wan1 pppoe and wan2 dhcp.
my suggestions.
  1. maybe ip cloud should be smarter and choose to update from wan that is direct connectet to internet (wan with pppoe client) and not behind nat (wan with dhcp)
  2. there must be an option in ip cloud menu to choose from which wan should always update.
Cloud uses cloud.mikrotik.com, so currently you can route its addresses (81.198.87.240, 91.188.51.139) through selected ISP using static routes. Only one address is possible, you have to choose which one you need most.
